Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature currently requires accessing the site using the built-in Safari browser.
Hello ES! We could use some help to get us past the finish line on building the new knowledgebase for the forum.
I would describe it the other way. It is a function of the Nine's higher output ratio relative to the Rohloff which requires a bigger input sprocket to slow it down.
Yes. If the sprockets are kept the same then the overall drive ratios from crank to wheel (e.g. gear inches) are a factor of 2 different with the two IGHs. At least one system would be quite unsuitable for use!
It is important to consider what needs to change to keep the overall system drive ratio the same (customarily measured in gear inches). Since the chain ring isn't changing, the only option is to change the sprocket at the input of the IGHs. This means that when a rider is going the same speed with the same effort and spinning the crank at the same RPM and has selected an appropriate IGH ratio to do so the pedal chain speed and tension will be the same. However, the resultant torque at the hub will be 2X different because the radius at which the chain is pulling on the sprocket has halved or doubled. The torque in this case is the chain tension multiplied by the particular sprocket's pitch radius.
