johnnyz383
Does anyone know what the resting full voltage of the headway 15 amp cells are?....I have been running the pack all summer without a BMS and decided to top balance the cells using a single cell charger. Most of the cells took around 3-4.5 amps to charge fully and when done almost all are at 3.33 volts except one which is at 3.2 volts...is this a defective unit or does it have less capacity then the others?
Thanks
John
Thanks
John
