johnnyz
Ok ive had numerous posts on this forum and heres the latest. I have a trike with 27 headway batteries wired serially ( I had 28 but when torquing down the bolt twisted the negative cap and although still working I dont trust it). These cells I got last summer and have about 2000 kms on them. I have not run a BMS but have bottom balanced them. When the highest cell is fully charged (around 3.7 volts), the lowest is around 3.45 volts and most others around 3.5-3.6 volts. I have a Crystalyte 18 Fet controller pulling a max of 60 Amps. Under full throttle it will sag down to about 75.8 volts from a nominal full charge of 89.5. I have split the pack into one 48 volt and one 44 volt pack so that I can use the Satiator to charge each. Each pack is connected using 8 gauge wire.
There appears to be so little usefull information on these cells especially under performance...this sag as a percentage represents 16% sag. The trike weighs 120 lbs and Im 175 so total weight of around 300 lbs.When cruising at around 40 kph using maybe 8 -10 amps it only sags to about 85 volts. Does anyone have data to support that this is too much sag or acceptable?
Thanks
John
Thanks
John
