dnmun
1 PW
you should not have any reason to need to monitor the cell voltages any more. once they balance, they will stay balanced. it is usually just the first few cycles where they are out of balance.
if they are .1% out of balance and you use up 7Ah then that is 7mAh or about (7/182)x60=2.3minutes to balance. and all the off cells will be balancing at the same time too so once it has settled into its permanent state, the charging will be very efficient.
adding more cable increases the chance of a short eventually too, and if it was a ribbon cable tied directly to the cells then they could discharge outside of the BMS control so that is too big a risk. imo
mondo monday! you can get the smaller soap tubs with a locking lid to keep out the rain.
i have some cedar paneling, 5/16" thick i may use for a frame, but now i am thinking i can also use up some of my old linoleum i saved from putting some in the bathroom in my shed. ineed to build a 12S headway/ping BMS to go with the E-Bikekit.com 36V10Ah lifepo4 pack i have too. wanna be able to get to 72V.
