dak664 said:
Can you measure the voltages while charging in series? With the flat voltage/charge curve for LiFePO4 I wouldn't assume the cells in a pair are equally charged until ~3.5 volts when the voltage/charge rise is steeper. When the cells in a pair are fully charged the BMS will bypass all the current it can but if the charging current is higher than that the BMS will cut off regardless of the voltages on the other cells, which would then trigger the charger voltage cutoff. I made a pack with one fully charged cell and had to charge at <100ma to keep it from tripping the disconnect, until I clipped a 10 ohm resistor across it which allowed increasing the charging current to 400 ma.
Earlier you said the cell voltages were all 3.3 after charging...that should be more like 3.5.
Hi Dak,
You're right, they're not at 3.5 because they're not charging all the way. I thought all of them were at 3.3, now that I think about it I might have missed checking one of the pairs or something. I guess it's time I started writing all my measurements down, I can't even remember whether I checked them all.
Ping told me that if I upgraded the charging FET on the Signalab V1 BMS, that I should be able to use my 10A chargers with his BMS, so I assumed it must be doing PWM, like the Fechter/Goodrum E-S BMS. This is next on my list to try.
I've only had a little time to play with this... but like you said, the most charged-up pair are briefly getting as high as 3.9V before the ecity BMS cuts the charging FET off completely, even with the 5A Ping charger. (sigh... b-bye Headway warranty on half my cells
). I assumed that the ecity BMS (looks like the exact same one KAE is selling) would start doing PWM on the charging FET to limit current once one of the channels reached the shunt voltage threshold.
Just out of curiosity, am I understanding you correctly that you're not seeing any real balancing happening with your Headway BMS unless your charger is limiting itself to less than 150ma? Seems to me that's not a very good way of doing things -- there's no way for the charger to know whether the shunt is activated on any cell groups... Shouldn't the BMS be doing the current limiting?
If the Signalab/PingV1 BMS does its own current limiting, then it seems to me it's the only good alternative to the Goodrum/Fechter BMS available. I guess I could balance manually and turn the charger voltage down a little but considering what I've already spent on shipping and BMSs at this point, I should have just bought these:
http://www.endless-sphere.com/forums/viewtopic.php?f=9&t=10758
