passpato
- Joined
- Jun 18, 2011
- Messages
- 89
My old 36v Heinzmann has blown two controllers in six months. The controller supplier says its an unusual fault and something they don't see often. At first I thought it was aluminum corrosion dust causing arcing on the armature but I have stripped the motor down and found the insulation damaged on the winding plate. See photo
http://www.flickr.com/photos/75570124@N02/6974559080/ copy and paste to browser
Is this my problem ? Does anyone know if I can repair this ? A new motor is so expensive.
I have a spare motor with a better winding plate but it too is making noises from behind the winding plate.I can't get the gear off the back of the shaft without breaking the housing. Has anyone done this?
See photo
http://www.flickr.com/photos/75570124@N02/7120644001/ copy and paste
Also does anyone know how to keep the shim and spring washer in its housing near the brushes when reassembling the motor? The magnets pull it out before the motor closes.
Any help appreciated
Marcus in England
See photo
Marcus in England
