Help -2 FarDriver for Dual Motor and Display Wiring
DualMotors
Anyone here can help me :
I have a FLJ 14K - 10KW - i removed everything and add 2 fardriver nd72450 - i been having problem to make a perfect settings for these 60V - 5000W dual motors but i ound a bit of information about lowering rpm and add up amper ages slowly, it not perfect like “ the Original Manufacturer Controller which only has 50A but push so heavy scooter just fine without any heat to battery or motors, but my setup now with 2 far driver it either heated my battery and my motors
Now another important is the stock display Ebike- liquid LCD that has 1 wire that said YXT , before that that 1 wire followed and connected with a LCD Throttle and it work, now i connect the 1 blue wore from fardriver but it would pick up any signal, could any help me with that experience? Here i have a picture of that display PCB
Only the YXT is what it read speed signal, any other are left,right,headlight..etc that I already know, but my question is what settings can i change in Fardriver Display that would send speed signal for this type of Display? Idk what is A-B-467-Soc solder terms are
Also can anyone guess the original manufacturer of 50A controller settings are? So we can copy it and use it in fardriver settings with a bit bump up for faster speed? The original settings for those dual 50A controllers no one knows
