HELP! 2012 giant defy composite 2 conversion?
Has anyone converted a 2012 giant defy composite 2 to an e bike? I would like to do a mid drive system and am not sure where to start? Any help would be greatly appreciated!
This one?
https://99spokes.com/bikes/giant/2012/defy-composite-2
Specs
Build
Frame
Giant Composite Technology
Color: Black / White/red
Fork
Advanced-Grade Composite, Full-Composite OverDrive Steerer
Rear Shock
N / A
Bottom Bracket
SRAM GXP, Press Fit
Stem
Giant Connect
Handlebar
Giant Connect, 31.8
Saddle
Giant Performance Road, Men's
Seatpost
Giant Vector Composite
Pedals
N/A
Groupset
Rear Derailleur
SRAM Apex
Front Derailleur
SRAM Apex
Crank
SRAM Apex, 34/50
Shifters
SRAM Apex
Cassette
SRAM Apex 11x32, 10-Speed
Chain
SRAM 1051
Brakes
SRAM Apex
Brake Levers
SRAM Apex
Wheels
Rims
Giant P-R2
Spokes
DT Swiss Competition, 14/15g
Front Hub
Giant Sealed Bearing 24/28h
Rear Hub
Tires
Giant P-R3, Flat Guard, Front and Rear Specific, 700x23
Right off the bat, I'd suggest a road bike like that, with short reach brakes that allow a maximum 25mm to 28mm tire, isn't really suitable for e-bike speeds and conditions. Do you really want to spend all your time on the bike scanning for imperfections in the surface that could end your ride?
I also note that a drop bar bike offers no place to put a throttle. If you're using PAS only, that's not an impediment, but I wouldn't want to go without a throttle as an override.
Mid drives exert their reaction torque by rotating backwards opposite the rotation of the cranks. If that's a plastic frame as it appears to be, you will need to protect the underside of the down tube from damage in case the mid drive unit loosens and smacks into it. A strip of metal mounted under there with double stick tape should be enough protection.
Lightest.bike's mid drive would be a good pick for a sporting road bike like that, but it is looking more like vaporware every day. And it won't be cheap if it finally appears.
Bafang M510 looks like another appropriate choice that might be available sooner and in greater quantity. Or not-- time will tell.
If you already own that bike, and you like it, then don't screw it up by converting it to an e-bike. A better donor for an e-bike conversion would be a steel bike with straight round frame tubes, rack bosses, generous tire clearance, and flat or riser bars. Surly Bridge Club and Fairdale Weekender are currently available examples, but the '80s, '90s and '00s gave us many to choose from.
Agree, the small tires are always an issue as well as the incredibly tight tire clearance around most road bike forks and rear triangle. If you’re willing to spend a few $ on upgrading with new fork, brakes and tires and maybe even using wider front tire than rear then sure - why not?
Chalo has a good point that composite frames are not the best for conversions and not what i would choose, they are sensitive to point stress (..any mount you need to have for battery and motor..)
Also riding geometry on this type of road bike will be focused on a tucked aero position and needs legs pumping to counteract some of the weight of your upper body if you’re using the bike seriously. I tried a conversion like this and didn’t really like it. I think more upright riding bikes are an advantage for electric conversions in the long run.
larsb said:
Edit: i just saw that this frame has a press-fit bottom bracket. I think that’s a showstopper as the bottom bracket is often one of the mounting points for many mid drives and that won’t work on a press-fit.
That's not a deal breaker, but it does mean that sleeves will be necessary to locate the mid drive unit on the BB shell. Luna Cycle offers some such adapters for American shells and other more recent BB styles.
https://lunacycle.com/pf-41-adapter-for-pressfit-bottom-brackets/
It's really just the fragility of a bike like this that should disqualify it for e-bike conversion. The technical challenges can be overcome.
