14" seems a little small unless we're talking about a woman's frame ( these are measured differently due to their much lower seat post )
If you can tolerate a regular mountain bike then that would be best for frame strength ( becomes important when going fast speeds )
Mounting a battery and other things in the center of the frame is best for weight distribution. Put a battery on the rear, and the rear will wag. Put it on the front, and the front will wag. All due to the battery's weight.
But in the middle of the frame, you won't notice the weight at all.
Ideally on a women's bike, you use the top tube to mount a battery because this is as close as we can get to neutral weight.
For other cargo, rear is ideal because if the wind blows sideways on a front loaded cargo, it will turn the handlebars with the wind. I find it's less dangerous to have the air hit the rear ( way less counter-correcting for wind is needed ).
Once bikes start going fast ( BBSHD is a pretty fast drive, capable up to 34mph on stock-ish power ), they start becoming less forgiving, handling wise. Suddenly you want a longer wheelbase, better front suspension, good weight balancing, stronger brakes, etc with this ~2x speed increase vs pedal bike speed
