Help connecting key switch throttle?
Hey I have some sort of Chinese controller and I recently bought a NB throttle with a key switch. The main throttle wires (Ground, Positive, and Signal) can connect fine with the controller but there is 2 extra (blue and yellow) wires coming from the throttle (I assume for key lock and voltage reading) but I don't have a key connection on my controller! Where do I connect the wires! If these wires are incompatible is there a way to short them so the throttle at least works?
The throttle does not need these wires to function. (high voltage battery power) But if your controller has an ignition, key lock, or something like a power lock circuit. It needs to be activated for the controller's 5vdc regulated output is energized. Which IS used by the throttle's hall sensor.
Look over this thread, it may provide you the clues on what to look for...
https://endless-sphere.com/forums/viewtopic.php?p=1505428#p1505428
If not your controller wiring diagram would be most helpful.
Caution: Do not mix the throttle's low voltage wiring with the high voltage wires :warn:
Regards,
T.C.
