Help Needed: Adjusting Voltage and Current on WATE-600W Charger (Trim Pots Turned by Mistake)
Moroz
100 µW
Paris
Hello,
I wanted to increase the voltage of my WATE-600W charger from 50.4V 10A to 58.8V 10A.
I turned the VR1 trim pot, but nothing happened. Then I turned the VR3 trim pot, and nothing happened either. However, when I turned the VR2 trim pot, the voltage increased. I fixed it on 58.8V
My problem now is understanding what happened when I turned the Vr1 and Vr3 knobs.
How can I return these two trim pots to their initial positions??
Did I inadvertently increase the current?
Could you please tell me how I fiddle around with these trim pots to ensure that I am not outputting more than 10A?
I need to charge my 14s6p Molicel battery, but I am hesitant to connect the charger to my battery because I am afraid of causing an overcurrent.
Do you think it's safe to try? (My battery charging port is connected to a BMS).
Thank you for your help!
use an ammeter to see how much current its outputting to the battery, you can turn it counter-clockwise to reduce the initial current if youre afraid afraid of over-current
Ok Thank you. the Bluetooth BMS that's connected to my battery indicates the current. Can i use it to monitor the current instead of wiring a ammeter?
Yes , you can use the bms to monitor the current.
