rg12 said:
but one question though...What if it cuts current at the end of the charge but the pack is unbalanced and need a bit of charge to raise a few unbalanced cell groups through the bms?
Now your getting into the question of how a BMS works. And an important one at that.
A standard BMS (exceptions for more expensive BMS's) will not begin to balance until at least one or more cell group reaches 4.2 volts or the maximum charge for that type of cell. That would require to have the output of the charger at least 88.2 volts. (21X4.2=88.2) At this point the BMS would allow the cell group with the HIGHEST voltage to
discharge VERY slowly thru a bleed resistor, dissipating as heat. And allowing the lower voltage cell group(s) to catch up. With this
slow discharging for balancing, and depending on the amount of imbalance, it would be unusual for the pack to be completely balanced when the charger first shuts off. Some chargers will automatically come back on when the the total charge is lowered enough thru the balancing process. But some you just let the battery sit for a couple hours, and then restart manually. The closer your current shut-off setting to optimal, the better.
If your charger is rated to charge LiPo batteries, this is no problem. And would allow it to charge to 100% and balance properly if adjusted to 88.2 volts output. Remember it is best to use it right after charging to 100% and NOT let it set with a full charge.
But with your original stated goal of only charging to 87.7 volts or under 4.18 volts per cell group, it may not balance at all.
This is why when one uses a charger that can also charge to 80, or 90 percent like my Luna Mini Charger. Which is used to extend battery service life. Needs to be charged at 100%
occasionally depending on use, to balance the cells. :wink:
So if your goal is to occasionally charge to a lower voltage to extend battery life, as Chalo mentioned above. A Si diode or two can temporarily be put in series with the charger output that has been set to the proper 100% voltage charge to reduce the voltage output for that particular charge cycle. Reducing total charger voltage. ( I think about .7 volts per diode) Keeping in mind that this will allow the charger to keep charging, albeit very slowly. Giving you time to terminate the charge manually at the lower voltage.
You could also install an inline volt/amp meter like this...Post #47.
https://electricbike.com/forum/foru...t-52v-11-5ah-huffy-parkside?p=72784#post72784
and terminate manually exactly when you want to.
