hjns
Hi all,
Today I was riding nicely along the road, when suddenly my rear wheel with the Clyte HT3525 hubmotor (sensored -methods version) lost fixation of the right axis to the frame (loose bolt). The rear wheel then touched the frame, it met a lot of resistance, and then stopped working. After I refixed the bolt and tried the throttle, no reaction of the motor. The CA nicely gives me my 80-odd Volts, and there is an increased resistance of the wheel when pedaling as compared to before the accident.
When I got home, I checked all connections (phase, hall, throttle, speedswitch, CA) and all is well. Motor just does not react. My question: before I open the motor, is there anything else that I can try? Or did I really just fry my motor....?
My setup:
Hardtail frame
Suspension front fork
Lyen 150V 12Fet controller
3-speed switch
throttle
regen was not activated
HT3525 with 8-speed 32-11t freewheel
20S2P lipo (4x 10S 4.5Ah Zippy bricks)
Thanks for all your responses!
edit: title changed to indicate that the problem has been solved
My setup:
Hardtail frame
3-speed switch
throttle
