The greater the angle of the helical gears, the quieter they will run. However, as the angle increases, the forces that try to push the gears away from each other axially increases. On the BBS02, the primary reduction gear-set is clearly very helical. When I first wrote about that drive, I was certain that the secondary reduction were "straight-cut" gears, and since the secondary spins much slower than the primary, the potential noise wouldn't be very bad at all.
Later, I happened to see a picture from a more optimum angle, and there actually was a slight angle to the gear-teeth on the secondary. Much less than the primary, but definitely enough to classify as helical.
In a gear-set with a high angle to its helical gears, I have ocassionally seen an axial "thrust" bearing. It can be anything between a simple precision bronze washer, all the way up to a needle bearing. I'm sure there are many factors to take in consideration. Is the lubrication grease? oil immersion? oil "splash" lubrication? Of course the optimum for extended severe duty would be a pressurised oil system, probably overkill for anything you'd need here.
If immersed in oil, a bronze washer can take up the wear (the sides of the steel gears wouldn't wear), but if you go with an annual cleaning combined with a smear of high-temp synthertic grease...perhaps go right to the needle thrust bearing. They are actually quite affordable.
