[HELP]Opus BT-C3100 V2.2 Smart Universal LCD
is this charger capable of reading the capacity of 18650 batteries??
im planning of getting the 18650 from dead laptop battery and want to check the capacity of the battery..
Yes it is an intelligent lithium cell charger that calculates mAh input during charge and mAh outpout during discharge. The Foxnovo 4S digital charger performs similar fonction. If you can, find a charger that can also read rough estimates of internal resistance.
Laptop cell is probably a bad idea for an eBike battery. I myself did the experiment in the past https://endless-sphere.com/forums/viewtopic.php?f=14&t=57810&start=150#p1213147
If your controller will only pull 10 or 15A, then mayby it could work, but you would need a very heavy pack. Don't count on a long cycle life. Also, laptop cells are made with LiCoO2 chemistry which is the most unsafe for the 18650 format... It can catch fire during thermal runaway. Example of the energy they can release violently:
https://www.youtube.com/watch?v=08BoXebt_pk
