I recently purchased a Home Built Electric Paramotor. Original Owner and builder was using a 20AH Lipo Battery pack and got approx 25 minutes of flight time. Second Owner was planning to build a 16s battery pack using 20ah LifePo4 prismatic high C rating cells in series. He was also going to include a BMS.
I am a noob to this stuff and know only the very basics when it comes to Electric motors and batteries. But from what I have been finding on the interenet so far I am leaning towards the LifePo batteries with a BMS. Another thing that comes into play is that I do not have the time or knowledge to try and build this battery pack myself. Would rather buy from a reputable source. Below I have listed the Motor Specs that I could find on the Internet. I am looking for ideas on what battery pack/configuration that would product the best power with longest run times and where I could buy one or have one made. Obviously I can only go so large cause weight is an issue but I would be very happy with 25-30 minutes of run time.
Motor: Hacker Brushless A200-6
Power range Max: 15000W (15sec)
Idle Current (Io) @ 8.4 Volt [A]: 5.1A
Resistance (Ri) [ohm]: 0.011
RPM/Volt (Kv) 151
RPM max: 8000
Any advice or help in this matter would be much appreciated. Thank you
RPM/Volt (Kv) 151
RPM max: 8000
