Allex
Helping out with a scooter here and right now I am not sure what it is, maybe you can help out?
It is a 16s40Ah lipo4 scooter with a quanshun like hubmotor stamped 2000W on it.
18FET 50A controller
The problem. When standing still and whacking the throttle it does accelerate very slow and jerky, like the motor shuts on and off. When applying light throttle on a flat ground, there is no problem.
So ok, I test the batteries and BMS, no problems there.
Checked the halls, and they all read 0-4,xx volts
Swapped to another controller, an Adaptto, it did autodetect (it does choose phase combo and hall combo/alignment automatically)without a problem. So I did a test drive and as soon as I apply more than ~10A the controllers cuts the load and the adaptto screen screams !HALLS!
So Ok could it be the halls anyway? I swap the mode on the adaptto from sinewave to sensorless and now there is no cut outs and no jerky acceleration.
Could it really be the halls, and in this case, how can they still measure 0-4,xx volts?
I remove the motor, and see that one of the phase wires have scuffs, it was chaffing on the metal scooter chassis.
My question now is, is it worth swapping the halls or could the whole motor be ruined by rust?
Rust:
Halls:
Phase:
Rust:
Halls:
Phase:
