BarryTrike
10 µW
- Joined
- Oct 21, 2010
- Messages
- 5
Hi,
I built the no-weld plywood recumbent trike, described here:
http://www.greatuserdocs.com/trike0.htm
Now, I would like to add an electric motor assist to help me get up the occasional hill (like right by my house). The hill is not too steep, but is too much for my weak knees and heavy trike. :? The motor would only run for about 5-10 minutes, and maybe 2-4 km/hour going up a few hills, on a typical ride. I am happy to pedal the trike on flats and gentle hills.
Since the trike was built from salvaged parts, I would like to keep the cost low. Preferably salvaged parts for this modification.
The trike has the rear left wheel equipped with the rear bicycle cassette (only the right rear wheel is pedaled through an 18 speed bicycle chain setup), so I would like to connect the motor via bicycle chain to this left wheel; the motor could be attached to the base of the trike. I would like to use simple lead-acid batteries.
I thought of using an automobile starter motor, but its connection to the chain might be a problem. I've seen a few web articles on using/modifying these motors. Here's one link: http://homepages.which.net/~paul.hills/Motors/Starters/StartersBody.html
My question: does anyone know of a source of a salvage/used motors that might work here? Is the automobile starter motor a good idea to pursue?
Thanks,
Barry
Thanks,
Barry
