A29Adriver@gmail.com
- Joined
- Aug 9, 2019
- Messages
- 17
I need help trying to find a good combination controller and display that work together.
I am putting them on a Xtreme Folding Bike XB310Li.
This bike is a mediocre bike, but I like it and would like a good controller/display. The bike is rated at 24 volts, but I have run it at 36 volts and it does fine.
I purchased a combination from Aliexpress; 24V/36V/48V 250W/350W Electric Bicycle Controller with LCD Display Panel E-bike Electric Bike Scooter Brushless Controller (https://www.aliexpress.com/item/32907301576.html).
I ran it at 24 volts and get error messages: 10 and 30 and communication icon, it will sort of work it I turn it on and immediately start pedaling it will kick in and work. If I hit the TAG/PAS button it will stop working and throw and error code. I have tried a number of different things to try a a work around, but the aliexpress controller and display don't seem to play well together and from other posts I have read on this website, it seems to be a common problem. I have also used 36 volt battery and told the system that it is 36 volts, but get similar errors. It will only work in PAS and the throttle has no effect, (Positive and negative and signal are correct).
I have emailed Grin technologies (they discourage phone calls on their website) and have not had a reply.
Has anybody, put together a good combination. I would do cheap, but would also do expensive (CYCLE ANALYST) if I know that the controller and display will work together.
