medusa569
For the past 4 days I've been trying to troubleshoot using the Lyen tester. I have the directions that can been seen elsewhere on this site. One thing I've noticed in the directions is that under testing controller it neglects to say whether battery should be turned on or not. I've also noticed there are no directions for utilizing the throttle wires on the tester..so what are they there for? I think I got a buggy tester as lights will sporadically come on solid when first turn on but blinks fin when wheel is rotated ( for phase and hall connections). I have never gotten the 5V light come on. Is there a way to test the wiring from the controller with meter as to whether I'm getting the 5volts?
IS there a way to temp by pass the throttle just to see if the hall sensors as connected ok . I noticed that if I switch up the phase connections I will still get the clockwise rotating lights. I don't know if that is unusual. I've checked my wiring and connections for continuity and all is ok ( except throttle as that is more complicated. Will some kind soul tell me how the h-ll to use this thing beyond the simple directions. And yes I've emailed Lyen and he hasn't answered past helpless response. I can call someone if that makes them walking me through it easier. I'm in EST.
