drunkencat129
- Joined
- Aug 5, 2008
- Messages
- 116
just go the last packs in woodbridge and maple stores
pwbset said:mikereidis said:So that'll be 5 virgin batts and 9 damaged ones...
And over $1,400 that could been used to buy a lot of PSI or a123. :wink:Tinkering is definitely an expensive hobby!
29a said:Have you guy's found out if the YW chargers do cell balancing or not
Is parallel charging OKIf so what if any extra protection is needed
do the leds on the packs actually give a real indication of state of charge![]()
Are the YW chargers still operating normal after doing the increase amperage mod![]()
It would be very appreciated if one of you guy's did a summary of the fact finding so far
Ive read and been following the thread but its getting long and difficult to find the facts from the testing.
mikereidis said:EDIT: 5 more ordered, 23.99 for express shipping; guess I got bit by Quebec PST since they use my shipping address, unlike when I pick up in Ontario stores.
no it dosent it just puts a charge and the crapy bms drains the cells to even them out but its crap29a said:Have you guy's found out if the YW chargers do cell balancing or not
drunkencat129 said:no it dosent it just puts a charge and the crapy bms drains the cells to even them out but its crap29a said:Have you guy's found out if the YW chargers do cell balancing or not![]()
ZapPat said:drunkencat129 said:no it dosent it just puts a charge and the crapy bms drains the cells to even them out but its crap29a said:Have you guy's found out if the YW chargers do cell balancing or not![]()
Seems to me that this is pretty much the way all BMS's do charge balancing, including Ping's and Gary's too.
Does the YW's BMS use FET(s) to cut off charge current when the first cell reaches the high voltage cutoff, then drain it down a bit, then turn charge current back on, etc, until all cells are equally charged? This is what I've heard every BMS does so far.
ZapPat said:On another note, has anyone checked out the mastercraft li-ion packs such as the one that comes with the drill for 99$ on sale this week? (Front cover item) If the mastercraft brand contains good lithium cells, it might become a good place to snag good cells. I'm thinking this because mastercraft brand comes on sale much more than yardworks, although this might not be true of the battery packs themsleves.
ZapPat said:You're probably right about the warranty period vs life span being one of yardworks variables in their decision not to add any individual cell OV protection. One of the sad signs of an economy based all too much on consumable products.
I guess this means slow charging (relatively low current) is the best way to go for these cells with the stock BMS.
GGoodrum said:The only "good" news about this is that even with the tools, packs can get to the point that the charger will fail them, so there ends up being a lot of service center returns. In most cases, almost all of the cells are fine, with at worst, one or two that are below 2.0V. Many of the returned packs have all the cells above 2.5V, which means they are all 100% recoverable. The good Doctorbass now has an excellent relationship with his local DeWalt service center, and he gets returned packs for free.All he did was go there, show them his ebike, and offered to let them ride it. Obviously this won't work at every, or even many, service centers, but it is definitely worth trying. You might look for equivalent YW/CT service centers, and see if you might use the same tactic to get them to cut loose with some "rejects".
-- Gary
GGoodrum said:DeWalt just disposes returned packs as well. They don't do any sort of repair on these, and they don't sell "refurbished" packs. That's why, in the case of Doc's service center, they don't mind giving them away, at least on the QT. The trick is finding a guy who likes what you are doing with them.Some will not get it, at all, and others might get it too well, and may keep the cells/packs for themselves, but I think there has to be more guys out there that are like Doc's new-found friend(s), and who will be cooperative.
The point is that if you can get packs for nothing, there's probably lost of salvagable cells. From what I've read about your experiences and the those of others here who have used these, the cells themselves are quite robust. Plus, they are in a very handy packaging format. All that is needed is a better BMS, or at least a cell-level LVC capability and a bulk charger with external balancers, or maybe a set of individual chargers.
drunkencat129 said:ill volunteers my YW battery packs for the bms ur makeing also do u got a setup thats a 5 sell at least me and steveo will test and post results so far for my 3s2p pack it gets about 2.26km per AH at 40a peak avrage is about 10amp draw load is about 26 to 30amps and im doing about 55 km\h on my e scooter with a 16 inch wheel
29a said:I stuck a astro lipo blinky between bms and pack using the from cells plug (blue is negative to blinky) and according to the blinky they were already balanced.
The same result on another two packs !
Ive only cycled these batts twice using the YW charger but I think they must be self balancing as i can't see them matching cells and balancing during manufacture.
Of the six packs i have, only the one bought with weed eater has security torque screws are you guy's the same ?
29a said:Am I correct in thinking the weed whacker is 9 amp so as long as i'm drawing more than that per parallel pack low voltage discharge shouldn't be a problem.
well for me i dont care about the size of the bms due to the amount of lead that my bike had lol i got battery space coming out my a$$ lolmikereidis said:drunkencat129 said:ill volunteers my YW battery packs for the bms ur makeing also do u got a setup thats a 5 sell at least me and steveo will test and post results so far for my 3s2p pack it gets about 2.26km per AH at 40a peak avrage is about 10amp draw load is about 26 to 30amps and im doing about 55 km\h on my e scooter with a 16 inch wheel
OK, will let you know. I'm very happy with project progress; still on track to have two prototypes built by Halloween.
Prototype schematics/layouts/physical design almost completed. Expect prototypes to be about 3.6" x 2.4" x 2" high with a few FETs vertical. Perhaps 1.5" high with FETs bent down. Possibly as little as 0.7"-1" high for compact production version; small enough to fit in large 25 cigarette pack.
Size does not include AC power supply but that could fit into a cube as small as 1"x1"x1" for a simple bridge rectifier pulsating DC supply.
Balancing resistors, and voltage divider resistors will be external, connected to battery lines.
Components/device will be generic enough to use for many purposes, like robot or RC model control, etc. Anything you can think of that doesn't take too much intelligence and uses up to 32 analog inputs resolved to 12 bits, and can control up to 32 digital/PWM outputs that can handle up to 1 Amp, or 100+ amps on all output channels using 32, 4110 FETs.
Project has me pumped... It WILL/MUST be done...![]()
