Awesome! You've definitely got the power there, just an iterative process of improving getting it to the ground
Just an idea - In drag racing world, one of the excellent relatively recent innovations is a driveshaft RPM vs time table
You know roughly how fast you should be moving over time based on previous runs, so you plot that in a table over time. If your driveshaft is spinning more quickly than desired, the ECU will pull ignition timing/throttle/boost, if your RPM is low then it will dynamically dial in more (up to configurable maximum modifiers). You can adjust the overall table X axis with a rotary switch, so if the track condition improves you can dial up power over time without having to get out the laptop.
Your time start could be triggered from the release of your 'creep' button, you would require man in the middle on the throttle and a speed signal. Of course this is only useful at the drag strip, unlike real tesla-esque traction control which has all kinds of other applications, but perhaps useful in the immediate term if it's easier to implement?
Unlike most you don't need to worry about gears which is a huge advantage in getting things dialed in!
Very exciting stuff
