Farnsworth
10 µW
- Joined
- May 5, 2020
- Messages
- 6
Hello,
I'm curious as I've seen high drain vs low drain being thrown around a lot. Most articles or explanations discuss what the basic differences are between the two types of batteries, but I can't find anything that actually explains why these types of batteries are different functionally or chemically.
The question is, let's say we are comparing two 18650 cells to each other.
An LG HG2 rated at 20A continuous discharge (6.67C rating) and an LG MJ1 rated at 10A continuous discharge (2.86C rating).
When I look at the specs of these two batteries, to me it almost seems as if the two cells are using the same chemistry, but they have been given different ratings by the manufacturer for marketing reasons.
Either this is the case, or the chemistry really is different on the inside.
So how does a manufacturer make a cell high drain and a cell low drain? Or is it simply marketing on their part to create a wider application use? Is an HG2 secretly an MJ1 but with the heat trip limit turned up to 6.67C? Could a "low drain" MJ1 for example be used in the same way that the HG2 is rated? If it can or cannot, why?
I believe that these cells most likely are different somehow, it's just interesting to see what ends up making them so different.
If you have any info supporting this it would be really helpful to share.
Btw great forum, I've found tons of useful info here.
Thanks!
Thanks!
