Hello guys,
I am complete newbie with this e-vehicle stuff and I am finishing my first build : electric kickbike with
HS3540 motor.
Some specs:
- Frame (steel) is 'Mibo Dextro' (http://mibospace.com/specs/dextro/dextro.htm)
- Motor: HS3540
- Battery: 18s (3 x Turnigy Multistar 16Ah) mounted on front fork
- ESC is Lyen 12 FET Mark II
- Torque arms (both sides) are 4mm titanium from E4Bike mounted to 5mm steel frame. I am not exactly happy with
the mounting hole being located almost at the end of the fork, but it was already present so I used it.
I am monitoring torque arms before / after each ride
- Rear wheel is 16" moped rim laced with 3mm spokes. The tire I use is 20" bicycle as the one targeted
for mopeds (which I bought) had some defect unfortunately.
- Total weight (ready to run) : around 34 kg
First riding impressions:
At the first, I set up controller very conservatively to 40A battery and 80A phase current. I took it for ride
with my friend and was very disappointed - there was almost no acceleration and I cannot climb
even not so steep hills. Also, at that time, Cycle Analyst was not connected yet, so I didn't knew what
watts are pumped into motor. I hoped, that this is not what direct drive motors can do.
For next ride I connected Cycle Analyst (unfortunately in legacy mode, so I cannot use throttle input remapping yet)
And configured the controller to 'unlocked' mode : battery current 100A a 300A phase current. This changed
everything. When I took it for a spin I was literally scared how wild the acceleration was. This exceeded my expectations
by large margin. I need to tame it somehow because throttle is little bit too touchy form my taste. Top speed
is about 65 km.h-1 on flat road and you get to this speed in about 3 seconds I guess. When doing this speed runs
CA reports about 7kW is pumped into motor.
Negatives (which are going to be solved
- Acceleration response to throttle is too aggressive for smooth riding. As you go over bumps hand on the throttle
moves slightly and scooter jumps abruptly forward. Not pleasing.
- Major negative (somehow expected): when climbing to hill (even mild one) motor gets very hot too easily (90 degs celsius).
I naively hoped, that the venting holes will reduce this problem, but now I see it is not that easy. I am reading
the threads about fan-inside-motor approach and I am keen to try it. Unfortunately this makes this vehicle little bit
impractical, but it is fun to drive it anyway.
Pictures:
The wiring of the ESC / CA is obviously work in progress
Old version:
Updated version:
HS3540 motor.
Some specs:
- Motor: HS3540
Pictures:
Old version:
Updated version:
