Hi all,
Basically my bike today, was working great at first - went in to work in the morning with no problem at all. Heading out from the office I came along, hit a couple of bumps as I went over the streetcar tracks and all of a sudden, no power. My lights and horn still worked, but the throttle did nothing. I went off the side, propped up the back wheel and throttled it - nothing. Took out the battery, put it back in, twisted the throttle - working. So I put back on the helmet and all, go back on the road, hit the throttle - nothing. Go back off to the side, disconnect the battery, make sure the breaks aren't at all stuck, turn it back on - and works. Back on the road and it died again. So I pedalled as fast as I could (got up to around 17km/h or so - bike usually cruises at 25km/h powered) - I managed to get it to work one more time while at the shop, but when I got back on the road, again it was dead.
I took it to a bike repair shop - I asked if they could disconnect the brake sensor thinking that might be it - the owner suggested it was the motor that had died, that because it was a 20" bike and I am putting so much weight on it, thats why it died. Before I got the bike, I checked the specs - it said a capacity of 100kg - I'm about 180, add on my backpack and so on takes it up to maybe 210 max. So I wasn't going past spec - and I told him so - but he said its what happens and I should get a 26" bike and toss this one...
Does anyone have any suggestions? I had the motor changed a few months ago (you can see my long thread from then) - I've probably only gone about 20 trips there an back total with it since then (so around 1,000km) - so it should last longer than that I should hope. This was my first week riding it every day this year after a cold and wet spring and I was really starting to get back into it.
Do you guys think it could be something else? I'm thinking to go at it with an ammeter tomorrow, but I'm not an expert on what to look for - someone suggested trying to hook it up direct battery to motor without the controller, but I'm not sure about that - he said to have a fire extinguisher ready if I did it
. Its a 36V Battery (confirmed the battery is fine, tested with a new one even) - other things are getting power - the motor is a 250W Bafang. I tried disconnecting cables one by one (reconnecting the previous each time) from the controller until I'd disconnected all the wires to the front end of the bike, but that had no effect. I haven't gotten it to work again since that time in the store. It all started from that hard jolt over the streetcar tracks about 5 hours ago. It seemed like the other wires were seated/connected in there, but I haven't looked too closely.
My guess is it could be the brake sensor (though they said they doubt it), the throttle (the pedal assist broke back in November so if the throttle isn't turning, that could also cause this), the motor, or the wires between. Those are just my uninformed/noob guesses tho.
Any suggestions are welcome,
Thanks,
Peter
Thanks,
Peter
