dnmun
1 PW
the cell logs will do that and there is a thread fechter started on how to hack them so they draw the current more evenly from the pack so it doesn't imbalance the pack during use.
wavezz2k said:Statistics says a lot, and frankly, we'll never know what sort of reject rate that they have. My belief is they sell tons. If quality suffers too much, they'll lose market share. "Who makes HK brand?" they states on their web site that the make slurry, pack electrolyte, and do final package and test. But yea, they are on the cheap side, which is why I'm experimenting with them. Once, ran more than a mile after undervoltage alarm going off, and had 1 cell on each of 2 packs which were 0.8 cell 'down' from the rest. Thought might had killed it, but recharged slowly back to full, and have since ridden another 15 miles (5 miles x 3 outings) with no noticed degradation; Perhaps if needed, it'd be easy to swap out a pouch for that matter, if one were killed by my error.. Definitely don't believe These LFP are 30c actual, but I've seen several tests run on their other LiPo packs which certainly deliver 30c with watt tests on R/C motors. Generally, when I do shut off at the cellmeter alarm, the cell to cell variance is .08 or less on each of these 6 batteries, 60 miles so far. Sorry, don't have more data on combined 72v pack with Lyen controller yet, as been busy on a multirotor bird .. plus it's been raining tons.
NOT trying to be an advocate nor a sales person, just sharing some data. Your mileage may vary.
I have about 12 HK & Turnigy batteries total, not one has a dead cell, each was shipped in a reasonably timely manner, with no damage. My experience: I can not agree that "they get out of balance quickly', as that has not shown up in any of my runs when LVC was respected. The wiring is not spacecraft grade, but works fine for 22amp 1000+ watt peak discharge using only 4 packs -
As soon as one of these LFP packs does die, I'll post it here, with circumstance and number of cycles. I truly wish someone with more miles (cycles) posted logged data, but haven't seen that anywhere. Any other reference data would be great - cheers.
wavezz2k said:Was checking back the Feb thread on HK LFP & $/watt,
looks like LFP has come down 25-30% in recent months (didn't know that, hadn't seen this prior, didn't know better, just ordered some). The points about A123 built up with BMS, ready to roll certainly make sense if you aren't changing your configuration about with testing...
by LegendLength »
Zippy 30C LiFePo4
Capacity: 69.3 Wh
Weight: 0.642 kg
Price: 79.88 USD
Density: 107.94 Wh / kg
Price / Capacity: 1.15 USD / Wh
Zippy 30C LiPo
Capacity: 92.5 Wh
Weight: 0.650 kg
Price: 54.85 USD
Density: 142.30 Wh / kg
Price / Capacity: 0.59 USD / Wh
A problem with that valid point is ... well... who has data on lifespan for these cells when not abused the way rc guys use them? They seem unlikely to last as long as the chemistry is capable of...iperov said:wavezz2k said:Was checking back the Feb thread on HK LFP & $/watt,
by LegendLength »
Zippy 30C LiFePo4
Capacity: 69.3 Wh
Weight: 0.642 kg
Price: 79.88 USD
Zippy 30C LiPo
Capacity: 92.5 Wh
Weight: 0.650 kg
Price: 54.85 USD
compare with W*h*cycles
dnmun said:i think ypedal has over 700 cycles on his lipo. maybe others can post up how many cycles they have. since the pouches are so vulnerable to damage, and the tape will distort them as they swell with age so it would be hard for these forms to last as long as the lipo in a can or prismatic. but charging and monitoring has to be the key imo.
boppinbob said:... How come HK lifepo4 has such a high c discharge rate compared to ping. Hobby King lifepo4 has a 30c discharge rate constant 40 c burst. Ping's have a 1 or 2 c discharge rate.
dogman said:The scuttlebut on those lifepo4 is the c rate is wildly inflated. Even so, should run a commuter wattage bike just fine.
dnmun said:if you used a 1/2 C charge and used a balancing charger they should not have puffed up like that then. i never understood how the battery medic can turn off the charger when one cell is overcharging. but a BMS is cheaper in any case.
dnmun said:quick charge is not a balancing charge. it has no way to balance the pack during quick charge so that may have been how it got puffed up.
dnmun said:90% discharged @ 3V resting voltage is pretty normal for lifepo4 pouches from my experience.
can you do your internal resistance measurement using two different loads?
measure the voltage and current at one current and then add a second load to it and measure the voltage and current there to determine the internal resistance of the cell.
It can't and doesn't. What it does is start bleeding off voltage on that cell and continues until the voltage is down to set voltage.dnmun said:i never understood how the battery medic can turn off the charger when one cell is overcharging.
Arbol said:From what I have read in this post, HK LiFePO4 batteries are low quality. The main problem is when a lot of current is requested from them (30C is exceedingly optimistic).
However, what would happen if one used these batteries for a small motor, say a 250W 36V one? One would need say 10A max, which apparently could be supplied by these batteries without puffing from demanding too much from them.
Another issue is the BMS:
em3ev has LiFePO4 BMS such as
http://em3ev.com/store/index.php?route=product/product&path=42&product_id=65
Would that work for these batteries? Could then one buy a simple LiFePO4 charger, and charge "plug and play"?
