In July 2012 I received an order of 9 packs of 6s, 5 amp hour, 20C Turnigy's, plus some cables and connectors at a cost of $580 shipped.
The packs were mostly run at 24s 2p, 88.8v 10 amp hours. Current has been between 40 and 90 amps. However past few months I've been running 24s 1p, again between 40 and 90 amps. So these packs have seen their fare share of high discharge rates. I keep the cells between 4.16v and 3.7v and try to keep them fairly balanced.
The cycle analyst says I'm at 170 cycles, however I've also run several dozen cycles without the cycle analyst so I estimate I'm around 200 cycles now, over 1000 amp hours delivered, over 4600 km.
Out of the 9 packs, 1 pack was damaged by a fire (my fault, cell punctured), so I've got 4 spare cells from that. I've found 3 bad cells in 3 other packs. The other 5 packs are in decent shape.
I've reconfigured my pack into 12s 3p, 44.4v 15 amp hours and set the controller limit to just 20 amps to be kinder to the batteries and also extend my range. I charged to 4.16v and discharged down to 3.7v and I got 10.8 amp hours, 500 watt hours which is 75% capacity. Most cells were between 3.7v and 3.8v after a brief rest. A couple cells were in the mid 3.6v range and one cell was down to 3.4v and needs to be replaced.
Once I replace the 3 bad cells and put all 8 packs back to work I expect I'll have greater than 80% useable capacity remaining after 1 full year of hard use. I'm hoping to get 2 years out the packs, but at a much lower C rate in the 2nd year of use.
