Hi Experts! Got a question regarding a battery built for an electric bike. The battery is a pair of 7s4p batteries used in series. I elected to use this pattern as I am not using a BMS and have purchased a super-duper iCharger duo battery charger which will charge both batteries simultaneously but each channel can do a max 8s battery with balancing.
Each cell is around 3.2Ah which makes this battery a 50.4V 12.8Ah battery. Anyone have a rough idea of expected eBike range with a batttery of this size?
So, the battery behaves nicely for the first 20 miles running it as hard as I can. I don't see much of a drop. Then it abruptly drops away. Okay, relatively normal behaviour for LiIo I guess. What my inexperience with the real world of these batteries is not telling me is what I should be seeing from the cells. At about the 20 mile mark my battery monitors start to beep (set at 2.7v) but when I get home, all the cells are well into the 3v range. Doing a short blast will see the (very simplistic) battery monitor on my handlebar display drop down and up again. So with the battery in this state I can then put the bike on the stand and put the system under load by running the bike on the hand throttle with the brakes on.
I can see that some of the cells drop markedly - down to 1.2V briefly. I'm told (is this true?) that it is the resting voltage you need to watch so that it doesn't drop below 2.5V. You can dip below this under load.
So in this load testing scenario, as soon as I stop load testing, the cells come back up to over 3V.
So does all this sound normal to you guys and gals?
So just to summarise:
What would be the expected range of the bike with this battery size?
Is it true to say that a LiIo cell can drop below its 2.5V threshold under load? (Resting voltage is the key measure here)
Is the behaviour described above a normal cycle for a battery pack?
One of the reasons I'm asking these questions is that the design I adopted for this battery makes it very safe because individual celll is joined to its buddies via short piece of 5A fuse wire before hooking up to the main pipe bus. Obviously this wire is very thin but the couple of cm of wire could potentially be a resistance which causes a voltage drop under load. My theory is that it's okay and 20 miles is about right for this battery and these indicators indicate I need to recharge, but I'm not sure so just checkin'!!
