Hummina Shadeeba said:
Am I understand that the N and L can be interchanged no problem? Ac current you can do that ?
I have a watts up power meter and also a turnigy 2 in 1 watt meter. Will I be able to keep those in the curcuit and get readings when charging?
That's the one I've got. Thanks. I'm tempted to take it out of the aluminum shell and take the fan off and stick a giant heatsink I found to it somewhere and then pot it in clear rubber. Glue it to the wall.
2 wire AC allows interchangeable wire positions ...
3 Wire AC should keep wire positions according to spec.
Power meter in line works nicely to monitor capacity and confirm voltage ... can use instead of multimeter to adjust-set charge voltage.
I've done a fair bit of research on this model, there are several mods documented.
See -
MeanWell Mods - S-350-48 for progression and mod instructions.
Recommend R33 (amp regulation) mod and fan mod. R25 mod to push voltage slightly higher, if needed.
Removing fan not recommended.
More concise-complete write up on the
ES-Wiki
