Questions regarding how a 72v @ 20ah battery would run differently than 60v @ 24ah (both 1,440 watts), for an electric motor...
The motor is 24-72v, 2,000 watt max, so I suspect one wouldn't want to go over 27 amps, correct?
Probably would be safer for the motor to keep it even cooler, like 1,440 watts?
Would both battery systems (72v @ 20ah and 60v @ 24ah) have the same top speed, or would the 72v be faster?
Would the 72v make the motor run hotter?
Would the 24ah battery run hotter?
Would the controller run any hotter with either battery system because of the v/a difference?
How would 72v @ 15ah be different?
