scotticeberg said:
I want to keep the weight evenly distributed, and as low as possible. Hence, the idea of the batteries in front low riding panniers. I like steel frames that can accommodate fenders, large tires, front and rear racks, etc. I've yet to see a full suspension frame that can meet all those wants.
If I was going to do a full suspension build, with the batteries in the triangle, I would almost certainly have to utilize hobbyking lipo, to keep weight and volume to an absolute minimum. My living situation does not permit lipo. Also, good full suspension frame/fork is easily four times as expensive.
I like the idea of being able to steer the weight of the batteries in a front pannier. I know someone in a previous unrelated post expressed a similar idea. If you have ever ridden a touring bike with loaded panniers you might relate to what I'm saying.
I also have no intention of a speed higher than 25mph.
QUOTE- "If I was going to do a full suspension build, with the batteries in the triangle, I would almost certainly have to utilize hobbyking lipo, to keep weight and volume to an absolute minimum."END OF QUOTE
FS or not, that statement is not true. Lot's of LiFePo and LiNiCo in triangles here.
Look at these shrink-wrap batteries, 15 Ah and even 20Ah fit in a EVFalcon bag, which in turn fits in most open triangles[even with a shock.]
http://www.bmsbattery.com/50-battery-pack
Very positive reviews on these battery packs are now coming in here,
http://endless-sphere.com/forums/viewtopic.php?f=14&t=33566&start=60
Cell_man makes triangle A123 packs specifically for triangle mounting.
If your goal is only 25 mph, a larger gear motor like the Mac, BMC or BPM on 36V will get you there.
Or a mini geared motor, likie the MXUS, Cute or Bafang will get you there on 48V. Easy Peasy for $500 to $800.
Yes, it IS unclear to me how hanging the weight of a battery pack on the rotating mass of the frt. fork could possibly improve handling as opposed to centering it in the triangle. Sure, folks here do it, because they don't have another option.
