Hello all,
I have a 36V eBike battery made up of forty 18650 cells (10series / 4parallel).
Sometimes, when charging the whole battery, the BMS doesn't balance the voltage correctly among the 10 packs. When that happens (which is often), I use an Imax B6 charger to charge each pack individually up to 4,2V:
https://secondlifestorage.com/imghost/glibor2.jpg
This can take up to 2 / 3 hours per pack, BTW :?
I just bought an Opus C3100 charger/tester and I want to use it to charge and test each 4p pack to determine their health (I'm pretty sure that 3 out of the 10 packs have defective cells).
I know I could tear apart the whole battery and separate each 18650 cell to be able to stick them in the Opus one at a time, but I REALLY don't want to do that! (it's a bottle battery and it would be HELL to reassemble).
The question, then, is: can I charge/test a whole 4p pack by rigging a cable from the BMS connector to an Opus' slot +/- pins?
I think some people are already doing it, but with fewer cells per pack:
https://secondlifestorage.com/imghost/ycsxfm2.jpg
Does anyone know if this would work safely for 4 cells welded in parallel (samsung ICR18650-22p / 2200 maH each), with a TOTAL OF 8800maH? Would the Opus give an accurate reading of the pack's capacity?
THANKS A LOT,
Alex
THANKS A LOT,
Alex
