How dangerous are Lipo's?
Montreal, Canada
I am a newbie to the forum and I have been reading up on the technology, both on this site and on others. I keep noticing people mentioning the fire hazards that Lithium polymer batteries pose.
How dangerous are Lipo's and how paranoid should I be with them?
thanks
zog
The ones we are talking about are the cheaply made lithium cobalt cells sold for RC toys. You have the same chemistry cell in your phone, but less cheaply made. Other chemistries such as lithium manganese types and lifep04 are less likely to have a thermal runaway.
But the hobby packs can be dangerous. Mistakes like a dead short, ovedischarging, and punctures can lead to a fire, particularly when recharging a damaged pack.
Lots of things in your house could potentially make a fire. But when we bundle together 6-20 of these lico packs together into a battery for a bike, we create a potential for a very large ignition source.
This does not mean in any way that a fire is inevitable. But steps taken to mitigate the size and and the probability of a large fire are smart. These cheap batteries should be stored carefully. Personally, I will not leave them on the bike in the garage. I do store inside, but in my fireplace, in metal boxes that limit the number of packs that could combust at a time. If the lipo rules get broken, that pack never comes inside again. I have a secondary storage outside for any suspect batteries.
Lastly, a dead short is always a hazard no matter what the chemistry. I had a truck burn once because of a dead short on the 12v car battery. If you are choosing RC lico packs to run 100v, think how much more fun a dead short will be. So pay attention to your wiring.
They are scary once they are all wired up together in a tangle of connectors, solders, wires and shrink wrap. They are great in use but you know you are potentially playing with fire. As said one loose connection out of the dozens you have will lead to trouble. Gulp! I should go and have a check of mine as i use them infrequently.
Not the best battery build for a complete newbie, They just want to discharge their contents in one big flash so you need to put them on a tight leash.
hahaha... And they still had to agitate it to make it go off.
People on this board will scare you to death about using Lipos when they are only a problem if you puncture them or charge them incorrectly. Worst is to use a bulk charger.
Lipos won't just spontaneous combust, so your bike sitting inside your house with batteries shouldn't just catch on fire.
I've punctured so many cells, had many puffed cells, with no issues.
unless you really know what you are doing - really, really dangerous, potentially. I set fire to my garage, luckily my kids woke me up before the entire house caught alight.
Some people have a good attention to detail and some people do not.
If you know you are one of those people you should be fine. Just make sure you understand the basics and keep track of each cells voltage.
If you know you are not able to keep a mental note on the state of things then get something safer.
Saying that id still never keep it in my house.
If in doubt check out another chemistry. Plenty to choose from and they keep getting cheaper.
They're kind of like owning the most powerful automatic weaponry you can legally own.
They're totally badass, but you better know what the hell you are doing with them when you get started, or there's gonna be a lot of damage.
Read my lipo tutorial in here, go look at some rc lipo fires on youtube and evaluate whether you are up to the task.
We should be using safer chemistries, for sure. But for some really high powered bikes where you want lots of range and lots of power... they're still the top choice, unless you can somehow come up on exotic/hard-to-get cells from major manufacturers that produce safe yet high power stuff that has similar density.
All of the above...and they (RC LiPo) are still one of the lightest , easiest to source and assemble,...and best value , $/kWhr, of all the battery options.
encore8899 said:
crzy russians...
https://youtu.be/gz3hCqjk4yc?t=41
Nice explosion that one.
Thing to remember with even a modest sized ebike lipo pack is at minimum x5 times bigger, so if you make a mistake you will have to deal with a much bigger longer burning fire.
There a number of sites popping up selling even in small mounts great value for money Samsung 25Rs that offer a lot of great hi discharge low sag performance. It makes the value side of lipo quite unworth while.
http://eu.nkon.nl/samsung-18650-inr18650-25r.html
Theres also a few seller threads selling 18650s from Teslas or retail packs for great prices.
http://endless-sphere.com/forums/viewtopic.php?f=31&t=61608
http://endless-sphere.com/forums/viewtopic.php?f=31&t=66384
As with this thread shows, people are constantly surprised by the prices high performance 18650 cells are available on the net for, even folk that sell them them selves.
http://www.endless-sphere.com/forums/viewtopic.php?f=14&t=57291&start=550
Can put it together via the JP spot welder.
http://www.endless-sphere.com/forums/viewtopic.php?f=31&t=68865
There are a lot of non spot weld 18650 pack examples out there, you can still use a lipo RC charger setup if you like as they run on the same voltages.
http://www.endless-sphere.com/forums/viewtopic.php?f=14&t=65719
http://www.endless-sphere.com/forums/viewtopic.php?f=14&t=66555
http://www.endless-sphere.com/forums/viewtopic.php?f=14&t=60517
If you contain the technical insight to build a lipo pack then you should have the technical insight to build even a basic 18650 pack with no BMS and just use an RC lipo balance charger to charge it.
I think with prices like those above lipo is just dumb now unless you have very specific needs of performance which some do but its a small fraction of people. Its just a wasteful way to build an ebike pack as the end cells tend to go bad quickly and most people just end up turfing the whole S6 pack or deliberately making it explode like so many videos you see on youtube, no one of those youtube lipo explosion videos are blowing up new packs theres always just one dodgey cell, its a total waste of lithium. I got a stack of old lipo in a metal box that I hope to eventually find some good use for but I wont be using any of it again for ebiking or buying any new lipo for ebikes, its just an old lazy and stupid way of ebiking for me now.
With the amount of choices these days, going LIPo is a risk you don't need to deal with. I could not recommend them, even though I use them myself.
thanks
zog
Well they're both really cool, and somewhat terrifying at times.
First part of the terror is shared with most of these massive homemade batteries.. you have high DC voltage, high amp capability, and alot of wires that are probably all the same color... so if anything goes together wrong.. doesnt matter if its an errant strand of copper wire, or wrong connectors or RIGHT connectors but not precharged... theres a very real possiblity of metal vaporizing in a blindingly white light.. no literally it can blind you. molten metal can pop.. things can go *poof* literally in smoke... all terrifying when it happens to you, especially in your face.
none of that is lipo specific.... any of these homemade packs could do all that.
It can REALLY get confusing with lipo if you're not careful.. for example lets talk about what I was doing the other night.
I have four big blocks of lipo.. each one is made up of four hardcase blocks of lipo in series. not a huge deal, each block only has 2 wires coming out of them, so build the block carefully, and move on, right?
well.. no. because once I have that, I have the balance wires. they all go in each block, but if any one is plugged in wrong, they WILL cause a wire to vaporize.
This is where the terror comes in. even though I plan everything. I label and color code. I do everything I can to foolproof it. but its still a small bit of terror to plug each thing in. especially the first time.
if anything shorts like that to vaporize, it may make the battery unstable.... not now. but later. Probably when I am NOT looking at it.
lets look at the battery.
its a thin aluminum pouch, and if it punctures... it will ignite with the air.
its a thin aluminum pouch, and if its undercharged... it will swell, and puncture and ignite with the air.
its a thin aluminum pouch, and if its overcharged... it will swell, and puncture and ignite with the air.
its a thin aluminum pouch, and if its held in compression so it wont swell, it will build pressure until the seams blow it out like a small bomb, and then it ignites with the air.
It also has a huge electrical potential, so it can short, create enough heat to ignite everything around it.... until its hot enough to melt aluminum... then it burns with the air.
its a thin aluminum pouch, and if its dented, bent or otherwise mangled, it can create internal resistance(heat, then burn), discharge improperly (overcharge on bulk charging,then burn) or go undervoltage(and then charge and burn)
ok, so its burning... but you can put it out right? well.. no. you'll have to let it go wherever it is. water will not kill it. your fire extinguisher will not kill it.. short of enclosing it in a Halon atmosphere, it will keep going. the fire departments water doesnt stop it, it just keeps everything around it cool enough that more stuff doesnt burn.
So all that said... you want to do it, safely. right?
well first, do you need it? if you dont need to go superfast AND superfar AND have space/weight limitations that cant be met by other methods.. sure. but most likely, something else will work for you safer, cheaper, and easier because its intended for consumers.
so you want to do it anyway, but safe as possible?
That means money. lots of money for things you didnt expect or think of...besides the batteries (they CHEAP in comparison.. right?)
Smart charger... because you need to balance them all.
dumb/bulk charger or super expensive charger... because the pack is massive and it would take hours to charge with the smart charger... unless your pack isnt that big.. and if its not big amp hour wise, why are you using lipo?
cell log, or other way of cell monitoring.. this does NOT replace a BMS, its what informs YOU of how well your BMS is doing.
Your BMS... this can be as simple as a plan to manually monitor.. or it can be a true system with a chip checking each cell voltage.
lipo balance connectors.. to connect them all. you need to parallel packs make taps for your cell log or other...etc
lipo balance connector wire... for above
lipo power connectors/wire... to get it all together down to your controllers power input.
multimeter.. a GOOD one.
software to log/monitor/figure out what pack or cell is good, and what sucks.
see all that? it costs money. the FIRST thing most people ask is... what above can I skip? they convince themselves they dont need a bulk charger, the smart one will work. or they dont need to monitor cells with a cell long, they'll balance charge everytime. or they will keep on track of things with no automatic alarms. or they will use their free harbor freight multimeter, and set their bulk supply with that.
they'll push to a full 4.2 charge everytime, instead of leaving headroom.
they'll run the batteries down to 3.0v "because they had to get home".
they'll forget that the controller lowers the battery slowly... or to check the balance... etc.
This is how most people are, and its rare for people to REMAIN otherwise after they get complacent with it.
THIS is the true danger of lipo. yes they can fail randomly, but 99% of the time its a failure of the human part, that allows the lipo to become dangerous in the first place.
people start out with the best intentions.
then they get used to it.
they then get lazy.
then shit happens.
oh, and one other prerequisite to lipo:
do you have a place where you can charge/store, but if your bike caught fire, it wouldnt kill everyone in the house?
this is from a previously unknown and uninformed poster
"its a thin aluminum pouch, and if it punctures... it will ignite with the air.
ok, so its burning... but you can put it out right? well.. no. you'll have to let it go wherever it is. water will not kill it. your fire extinguisher will not kill it.. short of enclosing it in a Halon atmosphere, it will keep going. the fire departments water doesnt stop it, it just keeps everything around it cool enough that more stuff doesnt burn."
this is all wrong. more misinformation by another person with no knowledge just like the guys who post up threads about charging lipo and talk about how it is "the most dangerous.....".
the risk of fire is because of shorted wiring. the batteries do not spontaneously explode. they do not just catch fire when exposed to the air. all wrong and deliberately meant to misinform people who have no experience.
lithium cobalt chemistries will go into thermal runaway when the temperature of the anode exceeds a critical temperature in an adiabatic environment. this is usually the result of overcharging the battery to extreme voltages or if it is involved in a fire where it becomes overheated.
THEY DO NOT EXPLODE.
well its a good thing the poster never said the word "explode"... he would be in trouble now.
There have been enough instances of RC Lipos exploding, venting, or leaking when brand new.
I have had one puff on me and then leak. Thank FSM that i caught it and put it outside when i noticed it puffing.
Lithium cobalt chemistry has a variety of reasons that it will enter the worst case scenario failure mode: major fire.
Even hobbyking will tell you that if you press them for information.
now now.. they dont "explode".. they just build an internal pressure that may burst from the foil bag. The internal slime flying out is not exploding, but experiencing a runaway thermal reaction.
its technically not an explosion.
Its just hot flammable stuff spewed out everywhere where it can catch other flammable stuff on fire.
beware the lipo police. :mrgreen: :pancake:
No, it's not an explosion. It's simply death metal show pyrotechnics-levels of flames that are extremely high and wide when a few hundred to a thousand watt hours goes up in flames all at once, destroying garages, cars, homes..
Way less harmful than an explosion!
It's less dangerous than gasoline. Still, if you're an idiot, you probably shouldn't use it.
http://endless-sphere.com/forums/viewtopic.php?f=14&t=27241
This is along the lines of my thinking too. More capacity for danger in my car's 20 gallon gas tank, but the car manufacturers have made it safe enough by putting controls in place. Yet still, fire and mayhem is always a potential.
That's why I put my own controls in place to mitigate risks of fire. If you study the art and maintain a level of diligence in the care of LiPo, they can be very safe.
TBH, I think the ocean is more dangerous, but we let our kids play in it.
High C-rate RC pouch cells are generally made with low quality materials and little to no QC on non-automated lines. From there, the pouches often aren't handled properly to avoid damaging the delicate pouch cells.
That said, if you are doing something that requires a 50C battery with decent energy density, there isn't much for an alternative.
If you're doing something that doesn't require extreme power densities, I would go with cells made on a production line that has strict QC and uses premium high purity materials. If the foil sandwich is laminated into a pouch or rolled up and stuffed in a can makes little difference aside from how they need to be handled and packaged. The can's are more robust for human handling, but in an event they can store pressure and explode a bit where the pouch isn't strong enough to let much pressure build before it ruptures. The pouches let you fill a given volume with substantially more active material due to not having inherent dead space between round cells, and pouch interconnects are generally more vibration robust.
Excellent packs can be made with round cells or pouches, but not if they aren't starting with quality cells, that's more important than the physical shape/package of the cell.
That's why i prefer uncompressed pouches.
They have some sort of headroom before they go kapow on you. There's a warning.
I've caught puffy batteries before they blow tiwce. I'd have no indication to NOT charge / use them again if not for the puffing.
