Stumper
1 W
My original post was here when I thought my problem was about batteries. Now I think it's about motor/gear/clutch slippage:
http://endless-sphere.com/forums/viewtopic.php?f=2&t=30009
Problem: No Torque
Ebay purchase: the bike has only done a couple turns around the block by the previous owner, 6 months old, no warranty. I suspect it has never worked correctly. Previous owner said he didn't gun it because he was cautious about running it in (as per eLation instructions). He may not have got to the point of it slipping.
Qn: HOW DO I TEST IF THE MOTOR/GEAR?CLUTCH IS SLIPPING?[/b]
Kit: eLation V3, 200w
When I put the motor under throttle the rear wheel turns (via chain drive) and the motor makes a certain noise. When I forcibly stop the rear wheel (not requiring much force) while the throttle is still on the noise of the motor stays exactly the same- which I'm presuming means it is doing the same thing - ie still turning. From this I'm assuming there is a slippage on one of the shafts (gear, motor, clutch).
The motor has a gear casing on it (see photo below). I took off the gear casing and clamped the primary gear (with some soft wood). I cautiously applied throttle and felt the force on the clamp until a heard a sort of click noise and the power went off. A little bit worried at this point - perhaps overload trip? I took the clamp off and tested the motor. It worked as previously. THIS MIGHT SUGGEST THE PRIMARY GEAR IS OKAY because the gear did not slip on the shaft??? But it was a pretty tentative test and I'm not sure if I sure do it again
The gear box goes from the primary gear into a another, then another with a sprag clutch/freewheel, then through the casing to the external sprocket (which has a chain on it and connects via the chain ring set). Perhaps then it is the sprag clutch failing (as had been suggested in the other thread linked above).
Qn: HOW WOULD I CHECK THE SPRAG CLUTCH/FREEWHEEL FOR FAILURE?
Cheers
Stumped
Problem: No Torque
Cheers
Stumped
