How does a IGH freewheel work ?
qwerkus
Hello,
Not sure if it's the right section. Can anyone explain or point to a good source where it is explained how the freewheel of an alfine 8 or a nexus inter 3 IGH work ? Would it be possible to remove it, to allow back-pedalling (and mid drive regen!) I've been looking around, and only found contradicting stuff.
Any help would be much appreciated.
Thanks for the reply. So am I correct to assume that there is not 1 freewheel, but (at least in a 3 speed config) 3 - one for each gear ?
No, still just one, on the input from the sprocket itself. Take a look thru some of these service manual / exploded diagrams and you may get the idea:
https://www.google.com/search?q=igh+exploded+diagram&num=100&newwindow=1&tbm=isch&tbo=u&source=univ&sa=X&ved=0ahUKEwjYlIb5yLHbAhUREawKHeR8CIoQsAQIKg&biw=747&bih=798
There's some stuff here too:
https://hubstripping.wordpress.com/\
https://www.sheldonbrown.com/sturmey-archer_3-spd.html
I would not expect a gearhub to shift right, or at all, without its overrunning mechanism.
