dogman dan
1 PW
Sounds like he wants fast, so no big deal with that. But 24s is a LOT. And that motor is fast. a 36-72v range controller would allow running at 10s 36v, 15s 52v, or 20s 72v. Get a high amp one, the fast motors need amps. You're still going to exceed 40 mph at 20s.
Riding that motor slow is quite possible, on the flat or easy hills. You just tickle the throttle, pedal along with it, and don't give the motor enough watts to make any heat. Efficiency might suck on the uphills, but if you are only offering it a few watts, the motor covers can shed the heat fast enough to have the motor reach a max temp that is not that hot. Don't try to ride it slow up really steep hills. You want to charge up those steep hills fast enough to keep the motor in it's more efficient rpm. If you plan on steep hills, I'd say get the HT version.
With the right controller, you have the ability to run at 36v, which will give you speeds much closer to the riders around you than being stuck at 100v.
It's quite possible to make an ebike that does two of three things, but a does all three is tough. I have lots of fun on ebikes that use very slow motors. Not much top speed, but the power is there if you need it on a steep hill. It's the way to go if slow riding is a priority. My approach gives me much more throttle controll on twisty trails that cannot be ridden faster than 15 mph.
What I'm trying to say is there is a reason some of us have three, four, or even more ebikes clogging up the garage. Each one does one thing really well. Build your fast bike to satisfy that itch. Then look into a featherweight lower power bike for riding with your buds. Or even two, so you can hand them one.
