Hi guys,
I'm currently developing a selb balancing unicycle as a project of mine. I've been looking at this motor http://www.conhismotor.com/ProductShow.asp?id=94 to do the job. I've done the maths and the power requirements is well above spec, but I'm having issues trying to make sure the torque will be acceptable at low RPM. I've worked out that at walking speed (2.24m/s) my unicycles wheel will do 84RPM. I'm struggling to find a value of torque at this speed. I'm concerned that I may need to buy a geared hub motor instead of this direct drive one.
Has anyone had any experience with hub motors at low RPM? I know that torque is inversely proportional to speed, so I'm assuming at lower RPM the torque should be higher? Can someone confirm?
Thanks very much!
Thanks very much!
