Hi everyone,
I'm working on a project with the BM1418ZXF 1000W 48V BLDC motor and I'm concerned about the torque specification. According to the datasheet, the nominal torque is only 3.5 Nm before reduction and 21 Nm after the reduction (1:6). However, I've seen many videos and testimonials where these motors move heavy loads without any issues. This motor is specifically known for its ability to move heavy loads in applications like rickshaws and cargo tricycles.
Even with an external gear ratio of 14 teeth on the motor and 38 teeth on the rear wheel that comes included in the kit, it doesn't seem to have enough torque to move 800 kg as the manufacturer indicates. But I've seen videos where it moves 500 kg without a problem. None of the mathematical calculations match the reality.
Can someone explain this discrepancy? Is there something I'm not considering?
I appreciate any help or explanations you can offer! I need this information for performing mathematical calculations for my design.
Thanks.
Thanks.
