How to convert E300 Razor with hub / brushless
rzyamazaki
100 µW
Hi, I am new to this site so if there are any mistakes, apologies on that. I have a E300 and I want to convert that into a brushless scooter. What wheel should I use to convert that (As in inches)? As I would like to make it as much as powerful. I was thinking of 10/11inch 52V1200W/ would that B ok :oops:?
If the resident e300 expert Hillhater comes and tells you the 11" is just fine you can go ahead, otherwise I'd think it might not fit.
https://www.aliexpress.com/item/32948196212.html
https://www.aliexpress.com/item/4000112135841.html
Ok, which on might fit ? I would like to have a powerful brushless motor that would fit in the E300. I think this link is better that I can use: https://www.aliexpress.com/item/32948196212.html
I would like to have like this beefy rear tire:
https://www.youtube.com/watch?v=ud3D0qRrqLc&t=284s
You reposted the 10 inch kit I linked, the Youtube video looks like the exact tire in the 11 inch kit I posted. So you can ask them if there's a 10 inch, but now I would wonder if he has the 11 inch.
That's right, that's Y I mentioned in the beginning that I want an 11 inch cause it looked similar. Unfortunately I am unable to message the guy as he has disabled the comments on his videos and neither I can contact him :( . I've tried to search him on this website as well as he mentioned that he has posted something here and TommyCat helped him. So what is it that U think I should use then? 11 or 10 inch? The fitting is not a problem as I can do that but I'm just confused about the electronics and etc. I was also thinking of making my own battery pack as I have a lot of old batteries of laptops that I can use. They are Li-on batteries and will make a good stack of 48 or 60 Volts. But I have 1 problem and that is how will I be able to charge it. I have lots of ideas in my mind for this project but the main this is I would like to know what Hub motor I would B using and from there then I can make the start.
