envisionelec
I’ve acquired two dead E300 HD brushless hub motor scooters and determined through testing that their controllers (HB-2416NL) were dead. They were free to me on a buy nothing group but it would be pretty nice to get them working for my kids. Razor shows the controller perpetually Out Of Stock.
I found a close replacement in the HB-2416WT for the E300 HDL but the seller has no wiring information and I’m trying to determine which control wires to swap or which ones go to the HDL's lighting circuits so I can use the process of elimination to ensuire first-time success. The motor, power and sensor wiring appear to be the same but the major difference seems to be the throttle and brake connector is integrated on one connector with a short pigtail to another one - maybe an interlock? I have made no effort to install them yet because I also need to buy new batteries in order to test it.
Are the connectors somewhat standardized or is it a free-for-all? The only other identifying information is the voltage and current: 24V 16A maximum.
Starting with the lowest effort ask - does anyone have a diagram for this or similar boxes?
www.monsterscooterparts.com
EDIT: UPDATE
I managed to tear down the original (confirmed) water-damaged controller and get the circuit board out. From there I deciphered the control signals and should be able to match them to the new controller. Worst case, I can buy another new controller for the purposes of tearing it down and figuring out the signals, because the assembly is kind of "one and done" and doesn't look easy to put back together.
This thread will hopefully help others looking for information about the E300 HD.
![www.monsterscooterparts.com](/sphere/proxy.php?image=https%3A%2F%2Fwww.monsterscooterparts.com%2Fmedia%2Fcatalog%2Fproduct%2Fcache%2F65138a5d834d223220f0e53fb23a345a%2Fz%2F0%2Fz09-1874_1_1.jpg&hash=88bd9024e5c3ad61f749f3be186a6b3f&return_error=1)
Control Module for the Razor E300 HDL Electric Scooter
Control Module for the Razor E300 HDL Electric Scooter Control Module for the Razor E300 HDL Electric Scooter
![www.monsterscooterparts.com](/sphere/proxy.php?image=https%3A%2F%2Fwww.monsterscooterparts.com%2Fmedia%2Ffavicon%2Fwebsites%2F1%2Ficon_2.png&hash=57eda6a93d3ba931ab19d4160ec39434&return_error=1)
EDIT: UPDATE
