Ypedal
100 TW
This comes up regularly, i get emails asking for help etc.. so i had to do this tonight and took a few pictures to illustrate.
Say you get a new charger, and the connector that comes with it does not match the one on your battery pack !
Ok, "no worries" you say to yourself.. you dig in your pile of parts and find the right connector you need to use.. or better yet, you switch to Anderson Powerpoles ! :wink:
Grab the wire cutters and cut the wire off the charger near the end.. slice the wire jacket and find non-standard colors !!!! or all black !!!! :x
For example, below we have Blue and Brown !
Since i'm using powepoles and they are unisex, i crimped a tip on each wire as i can pluck a red or black housing on either one.
Then set the meter to " DC V " . if you have a " - " and a " ~" symbol on your meter:
- = DC
~ = AC
Make sure each wire is seperate, very important that they do not touch, sparks will follow ! I assure you ! Sometimes followed by smoke(cheap chargers), sometimes not(better chargers)..
Don't worry about using the wrong probe on the wrong color.. just touch one voltmeter wire with one charger wire, the other with the other.. :
- = DC
~ = AC
