Stumper
*EDIT: I visited an engineering workshop this morn and I think I have a solution. See second post below.
So my sprag clutch has never worked............ so my ev bike has never worked.... so I'm trying to find a solution, ....and a sway between giving up and get a hub.........and then I think of something else I could try to do with the elation gearbox/motor:
If I some how fuse the sprag to the output shaft (ie replace it with something so that there is no longer a free wheel there) will that just mean I have to turn the motor over with the pedals if I ride without the motor turned on? And how much resistance would it be. Would it be no different to a DD hub?
Does anybody have ideas for how I could do this?
If it worked I might try to get a cyclone 14T freewheel on the output shaft in the future..
( EDIT: a Fitter/machinist has had a look at this and he says of that gear above that is not keyed, it would weld on with heat and there's no sign at all of slippage.)
Stumper
Stumper
