How to override errors 13 and 14 mosfet on a FarDriver controller
Waxhaw, NC
IMG_4394.jpegAfter dealing with this FarDriver bullcrap for a few days right as I was about to get my motor calibrated I got hit with this. When I first calibrated my bike after I did the FarDriver update it gave me these warnings because my controller was still in a processing state after updating. These warning codes should’ve cleared by now but because of corruption in my software they haven’t. I’ve already ruled out the two biggest other possibilities that was my motor being damaged , which it worked perfectly fine before the update and has no damage done to it. And my paras being dangerously modded which they aren’t , they’re stock from when I got the bike . And based on my situation that has happened so far it’s very likely I have corrupted errors that should’ve cleared. My main question is , are there anyways you can clear or override these corrupted error codes without using a physical dongle cord ? I’m not an expert and I’d like to avoid messing with things. If anyone knows of alternative ways to clear a corrupted warning or bypass it , it would be very helpful because I was right at the finish line of fixing my controller until my warnings from my previously failed calibration came back to bite me . Thank you!
