everythingisawave
- Joined
- Sep 13, 2016
- Messages
- 49
evc_motorcycle said:Hi everythingisawave, I believe that the only things that changed between my weird (kind-of) circular graph and the one I recently posted were the firmware on my controller and the order of my sin-cos wires. I had determined the correct color association, but then plugged them into pins 35/21 in the wrong order. There was also a bad connection between the +5V supply and the ME1302 encoder, so that wire had to be replaced.
After those few things, the instructions here: https://endless-sphere.com/forums/viewtopic.php?t=88647 were what I used. Our dynamometer is currently out-of-commission, so I used the method with setting 0 torque and spinning the motor with a power drill.
OK thanks. Looks like bad power connection would have done it, and also earlier on not enabling the forward switch during calibration, perhaps. Lessons learned..
