Mondo
I have a 160Wh V-lock battery that has somehow got out of balance (the manufacturer is claiming it is the PAG charger I used - don't ask me how, but I guess it's possible that he charger simply isn't compatible with the protection board installed. I do have a sep V-Lock charger that I purchased with these). I pulled it apart and I'm getting readings along the line of 3.5, 4.2, 3.6 and 3.8 - I've tried balancing it with my iMax B6 but it seems like it is too far out of balance.
Obviously there could be a bad cell in the high pack that means it is down on capacity and that's why it charge before all the others.
Question - is there any way without pulling the 4 packs apart of re-balancing it manually?
Should I discharge it all the way?
Sorry - I know I can balance it if I disconnect the cell packs but everything is glued together and difficult to access (I've already re-built one of these successfully with LG 3200's) so I'd rather not mess around with it physically till I've determined there is actually a faulty cell...
thanks - pictures to follow in next post when I get home.
