Hello,
I would like to replace the HR30 6 pins male connector of my BionX motor (ref HR30-6J-6P?) .
I tried to unscrew it, pushing, pulling it, without success.
Any idea?
There are some threads in there for the ones I buy, technically, but I don't see how that would help you. It just removes a little plastic jacket off the back. Here's one I soldered the wires to, but didn't screw the jacket on yet:
I would cut the cable, strip the wires, then solder them to a new end. Beware, it's incredibly difficult to solder these. Buy several new ones expecting to destroy a couple and make sure you have helping hand clips to hold everything together for you while you solder and a magnifying glass.
Would save several hours of your time to just buy a pigtail, cut the end off your bad cable, then use something like heat gun solder seals to connect each wire of the pigtail to your old cable:
