solarbbq2003
- Joined
- Apr 7, 2007
- Messages
- 500
i've got sensorless controllers 24v, 36v and 48v, they work with tongxin motor, not same brand as tongxin use, tongxin ones are not reliable
Knuckles said:Assuming the stator has slots. If so then sure (if not then use a dremel). Go to digikey and order some hall sensors and use some cat-5 network wire for the 5 leads. Heck upgrade the entire harness and you now have a brusless hub motor with hall sensors ready to go! These are the sensors I use btw http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail?name=480-1999-ND
Johnbear said:They don't truely freewheel, the motor spins. With a geared motor the motor is not always spinning. :wink:
gmouchawar said:Thanks Rick,
That was what I tried to do. Add the sensors somewhere. But I can't open the motor without unlacing the rim.
So it would be my last move.
Can't you do the same thing external to the motor? find the correct orientation and add magnets to replace the stator and hall effect sensors.
I can't find any info on the motor. It is made in Italy by ABB servomotor. Nicely made but difficult to use.
You are very knowledgable at this. I will leave opening the motor as my last chance because I would need to delace the rim.
What about adding rare earth powerful magnets on the case and sensing them with the hall sensors.
It is just a matter of finding where to place them and how many. I am assuming you need 3, 120degree apart!!! but they also have to aligned with something.
In any case, I have a new lead on a sensorless controller. I will post the results on that if it pans out.
Any other ideas are still appreciated. I don't have anything solid yet.
gmouchawar said:Rick,
What your proposed with the comparitors and opto isolators looks very doable. I drafted a schematic based on what you wrote..
If I settle for being moving before applying the throtle, would it work?
What refernce would be tied to the opto output? Wouldn't that still be the same gnd which I assume to be the bat negative?
Or would the controller have an internal reference for that signal?
On the comparitors does the phase signal go the + or -?
I know a co-worker who is good with programming PICs. but I agree if it needs to go beyond what you described in the 1st paragraph it wouldn't be worth it.
Thanks again for your insight. This has been intelectually stimulating regardless of the outcome.
