floppy2floppy
I have a Crystalyte HS3540 Motor that is about 2 months old, I got it from ebikessf.com. The motor runs great but it has a slight wobble to it. The wobble is not noticed while riding just if I pick up the back tire and give it throttle I can see the wobble, also the main problem is that I have a disc brake rotor on the motor, and the wobble moves the rotor enough that I can't have the brakes tight enough to provide good stopping power. If I tighten the brakes then it will rub at one point when the wheel does a full rotation. Does anyone have this problem, is this just the quality of these Chinese motors or can I do a bearing upgrade to tighten up the play in motor. Thank you in advance for the help.
