if you axe nice, perhaps these guys will sell you one.
NiMH only tho.
And yes, hub batts will always have a price premium attached cuz they come packaged in a well designed enclosure & BMS.
http://e-ms.us/lawenforcement.html
You have to keep in mind that there's not a whole lot of volume inside a wheel.
So it's not worth all the effort to roll your own, but I'm actually a proponent of a battery in the hub.
Been riding with one for three year & hop curbs multiple times on a daily basis.
The batteries bouncing around has never presented a problem & are probably more protected than a pack flying off the back of a rack at high speed.
The E-MS & WCL hubs are 12" dia. (compared to the X5 10") & even with the bigger hub they can only hold around 300 Wh which is barely adequate capacity for a first time/entry level ebike but not for anything hi-power.
I bought a dead Wavecrest hub-bat wheel for a hundred bucks & there's plenty of empty space inside surrounding each of the 30 NiMH D-cells, which I'm presuming the space is left there for cooling.
I figure by filling that empty space to the brim coupled with utilizing newer high density 335Wh/litre NiMH in place of the older original 200Wh/litre, I can squeeze in a half kWh of NiMH max & hope that internal heating will be less since I'll have a lower resistance pack made up of parallel strings that won't require as much convective cooling.
Alternately going with the highest energy density chemistry available to me, i.e LiCo, the most I could wedge into a 12" hub would be one full kWh, which is nothing to turn your nose at to make use of valuable free real-estate that's in short supply on a bike.
I hope that gives you some realistic expectations of what's possible if you decide to make your own.
I like that a hub-bat gives *you* the freedom to choose how to best utilize your payload space on the rear rack, between more battery or groceries depending on your requiremets in a given instance.
The hub battery is an idea ahead of it's time, once batteries become available with even just a doubling in energy density of the current crop then I think maybe you'll see more manufacturers package their ebikes this way.
And don't let anyone tell you about unsprung weight killing the whole idea, just like they'll tell you about the gyroscopic effects of a spinning mass, they have no idea what they're talking about.
The battery hangs onto the axle & don't spin, same as the STATor of a hub motor, it is STATionary.
The Wavecrest hub battery is around 15 lbs which up to that weight is a non-issue, altho I wouldn't want to go much above that.
I can dig up for you if you can't find it for yourself a recent posting on the power-assist forum by the chief engineer from E-MS a good explanation about the tradeoffs involved in unsprung weight & why he thinks a hub battery's low c of g is an optimal design choice.
