Well I've been investigating a bit recently and found out there are few options to set up a reliable and bombproof front hub motor. But they exist! Let's see what I've found out so far, and hopefully get a couple more ideas together on top of that.
First we need a fork that's sturdy enough, preferably a double crown DH fork. To allow the axle into the dropouts, you either need an USD fork (Shiver, Dorado, DNM, Zoom) or a fork with removable brake arch, like the old school Marzocchi Monsters or Z1's that are not made anymore but can be found used at about USD 200-300.
The latter have a problem with axle design - unlike the USD forks that mostly employ a plain 20mm axle, these have a variable diameter axle with skinnier end section that's threaded rather than clamped in one of the dropouts, which makes fabbing an adaptor even harder for an average lathe user.
USD forks are great since they can be slid outta crowns and right onto the motor, using a 20mm OD adaptor. On top of that, a ZOOM fork can be had very cheap considering the amount of metal and rigidity. But for me they are a no go since they have no brake arch and thus can't use a mudguard close enough to the wheel. Their huge amount of travel makes it no better, though there are ways to reduce it.
Then there are moto forks, but they are at least twice as heavy and kinda defeat the idea of a bicycle altogether.
The last but not worst possibility is find a cheap fork with cracked cast lowers, like this one:
http://www.bikemagazin.sk/bazar/7-vidlice-tlmice/1851-888-rc.html
Then fab some kind of steel reinforcement brace to keep the brake arch together, and double as a mudguard holder.
An extremely viable option would be machining down the standard dropouts and use two oversize DH 1.5" steerer stems as new dropouts. The onepointfive standard has 38mm which could fit forks with 30-32mm stanchions and provide a huge 4-bolt clamp for the axle on both sides. But the fork would certainly become shorter, so a 26" fork would no longer be good for 26" wheels. A 29er fork could be just what we need then.
